Текущее время: 20 авг 2019, 14:04
Часовой пояс: UTC + 3 часа [ Летнее время ]
Начать новую тему Ответить на тему  [ Сообщений: 157 ]  На страницу Пред.  1, 2, 3, 4, 5 ... 11  След.
 Заголовок сообщения: Re: Innocenti Radium T5 300i
СообщениеДобавлено: 12 фев 2019, 15:52
Скутер: Radium 300i
В инструкции написали: XY 175 MIV-3. В интернете нашёл клон скутера:XY 300 T-5, Xingyue Group Co. (Zhejiang Xingyue Vehicle Co.). Но про него вообще ноль информации.
СообщениеДобавлено: 12 фев 2019, 15:58
Интересовало, реальная модель двигателя. То, что написано на двигателе.
Правильнее, это Innocenti Radium клон китайского.
XY300T-5 parameter table
1, VIN: L4STHP85*A2
2. Dimensions (length × width × height): 2195 × 775 × 1495mm
3, wheelbase: 1480mm
4, track: 895mm
5, the minimum ground clearance: 177mm
6, the whole vehicle conditioning quality: 165kg
7, the factory set the maximum total mass: 315kg
8, the whole vehicle quality of the axle load distribution: front wheel: 67kg
9, the whole vehicle quality of the axle load distribution: rear wheel: 98kg
10, the factory set the maximum total mass front and rear axle load distribution front wheel: 127kg
11. The front and rear axle load distribution front and rear wheels of the factory set the maximum total mass: 188kg
12, the maximum capacity of the fuel tank: 11L
13, economic speed fuel consumption: 3.5L/100KM
14, the highest speed: >120km / H
15, the height of the seat cushion from the ground: 830mm
16, the minimum turning radius: 5000mm
17, headlight specifications and quantity: 12V35W/35W (1)
18, taillight specifications and quantity: 12V21W/5W (1)
19. Specifications and quantity of turn signals: 12V10W (4)
20, license plate specifications and quantity: 12V5W (1)
21, the number and specifications of the rear brake lights: 12V21W (1)
22, battery specifications: 12V9A
23, crankcase lubricating oil capacity: 1.2L
24, gearbox lubricant capacity: 250ML
25, tire specifications: 140/70-16 after 140 / (consultation specials)
26, front tire pressure: 200Kpa
27, rear tire pressure: 250KPa
28, hub type (front wheel, rear wheel): front and rear aluminum wheel
29, wheel specifications (front wheel, rear wheel): the first 3.0-16, after 4. (consult special)
30, front wheel brake type: disc brake
31. Rear wheel brake type: disc brake
32, front wheel control mode: manual
33, rear wheel control mode: manual
34, engine type: single cylinder, four valves, four flush water cooling
35, engine model: XY175MN-3A
36. Cylinder diameter × stroke: 75 × 66.8mm
37, Displacement: 295.1ml
38. Number of cylinders / number of valves: 1/4
39, compression ratio: 9.6:1
40, maximum power and corresponding speed: 16.8 KW / 7000r / min
41. Calibration power and corresponding speed: 16.2 KW /6500r/min
42. Maximum torque and corresponding speed: 26Nm/4000r/min
43. Minimum no-load stable speed: 1600±100KW/r/min
44, spark plug gap: 0.8 ~ 1.2mm
45. Ignition angle: 10oC~38 oC before the total stoppage
46, clutch type: dry clutch
47, magnetic motor series: 8
48. Minimum fuel consumption rate: 340g/KW/KM
49. Ignition mode: Inductive energy storage ignition
50, start mode: electric start
51. Primary transmission ratio: 40:15=(consult special price)
52, the final transmission ratio: 42:14 = 3
53、Packing specification: 2220×750× (consult special price)
54. Loading capacity: 32 units
https://drive.google.com/drive/folders/0B4xqEvZRMhq2dmNvNnZNNEwxUWs?usp=sharing
(выделить\правая кнопка\открыть в новой вкладке\окне)
СообщениеДобавлено: 12 фев 2019, 17:32
Скутер: GXomegaS150
Стаж: ∞∞∞
У меня выбор оооочень ограниченный. Глубинка. Заказывать через интернет -жаба давит, с пересылкой дороговато выходит. Плохое, но не "очень"или не "смертельно" плохое?
Ну не знаю,мне лично очень не понравилось;
1.Очень короткий ресурс-быстро чернеет,много лаковых отложений выделяется.
2.По субьективным ощущениям видимо толстый масляный клин,мотор хуже раскручивается.
Ну а так то совсем уж смертельных масел не бывает(кроме палёного,конечно).Впринципе,если масло в моторе есть,то уже не смертельно. :)
Не могу себе представить глубинку,где есть ЗИК и нет газпромовского.А какие у вас масла имеются в наличии?
СообщениеДобавлено: 12 фев 2019, 17:59
СообщениеДобавлено: 12 фев 2019, 19:33
Скутер: Radium 300i
Это, скорее всего, реальные цифры.
Это он и есть. Завтра точнее рассмотрю.
Последний раз редактировалось SanchSanch 12 фев 2019, 19:42, всего редактировалось 2 раз(а).
СообщениеДобавлено: 12 фев 2019, 19:41
Скутер: Radium 300i
Автомобильные разные. Для скутеров 4Т - ZIC. И минеральное Rezer.
СообщениеДобавлено: 12 фев 2019, 20:09
Скутер: GXomegaS150
Стаж: ∞∞∞
Я автомобильное ЗИК имел ввиду,скутерный ЗИК не пробовал,но не думаю,что оно лучше. :)
Скутерные и мотомасла хорошие на мой взгляд мотюль и ени,кастрол скутерный тоже раньше хороший был.
Но мотомасла импортные сейчас сильно подорожали,не обязательно на них тратиться.
Из автомасел,то что мне понравилось на практике могу посоветовать:Газпром 10w40 SL полусинтетика,ещё тоже газпромовское Джи-энержи 10w40 SL(но оно подороже,но ничем не лучше) и Маннол молибден 10w40 SL(бензин).
Они не дорогие,но показали себя очень хорошо;и термостабильность хорошая и мотор прекрасно на них крутит,даже зимой.
СообщениеДобавлено: 13 фев 2019, 13:45
Скутер: Radium 300i
XY 175 MN-3
Комментарий к файлу: Вот марка и номер двигателя.
Номер двигателя.jpeg [ 93.31 KiB | Просмотров: 970 ]
СообщениеДобавлено: 13 фев 2019, 13:48
Скутер: Radium 300i
На редукторе не вижу других приметных мест, кроме заливного отверстия и сапуна вверху. И сливного отверстия снизу.
Редуктор Заливное.jpeg [ 113.78 KiB | Просмотров: 970 ]
СообщениеДобавлено: 13 фев 2019, 15:02
Скутер: GXomegaS150
Стаж: ∞∞∞
Посмотрите среди крепёжных болтов.
СообщениеДобавлено: 13 фев 2019, 15:34
Скутер: Radium 300i
Может быть, что уровень заливного отверстия и есть "ограничитель"? Лить под завязку. Ведь сапун значительно выше его.
СообщениеДобавлено: 13 фев 2019, 16:18
СообщениеДобавлено: 14 фев 2019, 04:03
Обычно так.
СообщениеДобавлено: 19 фев 2019, 16:53
Скутер: Radium 300i
Система охлаждения. Есть вопросы.
Комментарий к файлу: Что-то не очень понятно место расширительного бачка в системе охлаждения. Или у меня заскок?
Расширительный бачок стрелки.jpg [ 892.66 KiB | Просмотров: 866 ]
СообщениеДобавлено: 19 фев 2019, 17:02
Скутер: GXomegaS150
Стаж: ∞∞∞
Ну бачок как бачок,что непонятного?
